Aerostar Ford Aerostar
4wd light blinks twice
Old 04-04-2007, 05:33 PM
jp1956's Avatar
jp1956
jp1956 is offline
Anybody have an idea what causes this? It sounds like a sensor problem but I can't find a list of codes to know which sensor.
Old 04-04-2007, 06:04 PM
copper_90680's Avatar
copper_90680
copper_90680 is offline
Hi JP1956
Welcome to our FTE forum
Code 2 means the clutch coil on the transfer case has an open circuit.
Old 04-05-2007, 05:01 AM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
probably the clutch coil plug/socket connecter corroded contacts...
FF1 CHECK VOLTAGE AT CLUTCH CONNECTOR
Disconnect the clutch harness connector from the clutch line on the transfer case housing.
Set the voltmeter to the 20 VDC scale.
Turn the ignition switch to ON.
Shake the clutch harness and check for battery voltage between the clutch connector pin and chassis ground.
2 wire connector over transmission input shaft on passenger side top of transfer case...furtherest one out...other 2 connectors are front and rear axle speed sensors
check for 12v to connector and any corrosion on contacts pin and socket....put silicone dielectric grease on electrical contacts for protection
if you find corrosion in connector, also check the 2 axle speed sensors....common failure in our AWD Aeros in wet climates, snow and mud driving.
Old 04-08-2007, 10:16 PM
jp1956's Avatar
jp1956
jp1956 is offline
Thank you
Cleaning that connector did the trick.
