Transmission Paint?
Old Apr 4, 2007 | 04:28 PM
fastmover's Avatar
fastmover
Question Transmission Paint?
Hi,
I have my FE 360ish in the shop for a rebuild to a 390. While it and the transmission are out, I want to paint the transmission (4 speed manual, see pic in my gallery). It has some light surface rust.
My plan is to treat it with Rust Bullet or POR15 and then paint it. Do I need to use a special high temperature paint? If I do, which do you recommend. If I don't can I use rustoleum?
Thanks,
Karl
Old Apr 5, 2007 | 05:20 PM
385seriesHemi's Avatar
385seriesHemi
Yeah the transmission is like an engine it will heat up, just not nearly as hot as the engine. Plus the heat from the engine itself. So any high temp paint will work.
Old Apr 5, 2007 | 08:12 PM
big J.V.'s Avatar
big J.V.
If your just wanting to put a decent looking coating on the tranny, I'd recomend going to your local hardwear store and picking up some high temp bbq grill paint. I have used it on engiens before and it holds up really well.
lmd91343
Mar 30, 2010 06:59 AM
rangermike
15
Mar 3, 2009 11:04 PM
balingwire
Dec 19, 2008 10:50 AM
mfd18
Paint & Bodywork
Nov 29, 2006 03:53 PM
laynrubber
Jul 15, 2006 02:08 PM
