New Coils?
Old Apr 4, 2007 | 12:12 AM
rogmale's Avatar
rogmale
New Coils?
I'm seeing some sagging on the driver's side front of my '66 f250. Thinking about replacing the front coils but have found HD's and variable rate as replacements. Anybody have pro's/con's on the two types? Wouldn't mind having a bit more lift, but don't want to stiffen the ride much either. Thanks for the help.
Old Apr 4, 2007 | 08:45 AM
acheda's Avatar
acheda
The variable rate springs cured bias-ply tire wear pattern problems when they came out decades back. I don't know if there is a problem with radials. My '65 F-100 had load range E radial tires and original springs and I had no problems. Ditto my '68 F-350. (I am assuming you are 4x2.)
Changing ride height is an issue with twin I-beams - higher than stock height will give you too much positive camber. I think you will find that the HD springs are designed to maintain the correct ride height with a vehicle that is always loaded. When not loaded, you will have too much camber (tires will wear on the outside) and a harsh, choppy ride.
Given the choice, I would choose the variable rate springs. They have less problems with resonances on concrete roads that have a regular pattern that can "excite" these resonances, giving vibration problems & tire wear.
Old Apr 4, 2007 | 08:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Original front springs for a 1965/66 F250 2WD ranged from 1055 to 1300 lbs.
Old Apr 4, 2007 | 11:42 PM
rogmale's Avatar
rogmale
That's a big help, not much cost difference between the types, getting a bit smoother ride would help the old girl. Thanks
