starting problem
Old Apr 3, 2007 | 08:18 PM
ratpak96's Avatar
ratpak96
starting problem
I bought a 05, 6.0l with 160,000 km with starting problems. It runs great but when I'm cold starting it takes about 3-4 seconds. When its warm it starts right away. any idea's why it does this?
Old Apr 3, 2007 | 09:28 PM
BAF350's Avatar
BAF350
I just had a similar problem with my '03 6.0L, it was hard to start and drive at any outside temperature but once the engine temp reached 120 degrees or so it ran like a top. All it ended up being was in need of the latest flash from the dealership. Cost me $125 and it was the best money I ever spent. Just something to check out.
Old Apr 3, 2007 | 09:41 PM
npccpartsman's Avatar
npccpartsman
You might try the new flash, but I don't think 3-4 seconds is a long crank time, if that's what you mean. It will help with your injectors if they're being cranky and it's a good flash. It definitely won't hurt.
Old Apr 4, 2007 | 08:52 AM
msgtg's Avatar
msgtg
I agree....once you've started the truck once and go to do a re-start it should fire right up because everything is already warm.
