1978 - 1996 Big Bronco
Blowing Fuses
Old Apr 3, 2007 | 08:13 PM
allwthrrider's Avatar
allwthrrider
Blowing Fuses
Hello All
I have a 1989 Bronco that keeps blowing the fuses for the turn signal circuit, My turn signal switch is bad to where it won't click back to off when striaghtening the wheels,could this becausing an arch in the wheel or is there a more common area to look? Any help would be appreciated thanks.
Old Apr 3, 2007 | 11:36 PM
justshootme84's Avatar
justshootme84
You likely have a short in the wiring to one of the turn signals. Check for any exposed wire or a spot where the wire is arcing to metal, like under the rar bumper or inside the fenders. My left turn signal works, even though the lever "Clickie" dealie is broke like yours.
Old Apr 5, 2007 | 08:12 AM
scurbiedog's Avatar
scurbiedog
I had a problem with the tail light fuse going and it was in the turn signal switch because the hazard switch is part of the turn signal switch and the only other thing on the circut, it would blow the fuse, so your turn sinal switch may be bad.
