Diff ratio is wrong?
Old Apr 3, 2007 | 01:18 AM
emptyd's Avatar
emptyd
Question Diff ratio is wrong?
Based on the door column stick:
I believe I have a 3.73 diff. ratio (axle code C1)
But hard numbers seem to arguing. At 65 MPH I turn about 2100 RPMs. Based on an RPM calculator Monsta pointed out:
http://www.angelfire.com/space/slr/RPMCalculator.htm
Using value of:
MPH = 65
Tire Diameter = 31.6 (I double checked this)
Axle Ratio = 3.73
Transmission High Gear Ratio = .71
I get an expected RPM of 1832
If I switch over to using
Axle Ratio = 4.3
I get an expected RPM of 2111 - much closer to what I'm seeing.
So which do I believe, my build sticker or the numbers from the calculator? Am I missing something? I'm going to be opening up the rear diff. on Friday - is there a sure way to tell by looking at the insides?
Old Apr 3, 2007 | 03:38 AM
1buzzbait's Avatar
1buzzbait
according to yer vin,your vehicle has 3.73's
Old Apr 3, 2007 | 04:35 AM
phil6608's Avatar
phil6608
Sounds about right for a 3.73
I have 4.10s and I'm running 23 to 2400 RPMs at 70 MPH
Old Apr 3, 2007 | 06:56 AM
manglass's Avatar
manglass
Sounds correct for 3.73's. That's right about where mine runs.
Lou
Old Apr 3, 2007 | 09:07 AM
emptyd's Avatar
emptyd
1buzzbait, where did you look that up? Website?
Old Apr 3, 2007 | 09:50 AM
areed's Avatar
areed
Have you checked the tags on your differential?
Maybe you had some aftermarket modifications from a prior owner...I guess this would only apply if you aren't the original owner.
I'd be real curious to see what your diff. tags say.
I run 4.30's and at 65mph I'm up around 2100-2200 rpm. 70 mph is about 2350-2400 rpm.
Old Apr 3, 2007 | 10:27 AM
1buzzbait's Avatar
1buzzbait
i checked the vin also,it came from the factory with 3.73's if the rear diff was changed it wouldn't change the tag!
Old Apr 3, 2007 | 12:07 PM
Monsta's Avatar
Monsta
Sit. Stay.
??? Do you own an Excursion with stock tires ??? Your sig doesn't say you do.
I would bet on a wrong tag before I bet on a wrong ratio. Just to make sure you should get a few different calculations from that site and test 'em out. Like 40mph in 3rd (1:1) and other speeds in 3rd. I like third because it removes the a slipping TC from the equation. (Just make sure it is locked.)
Listen many things could be off. The speedo, the tach, the tag, etc. etc.
Honestly, the absolutely best way is to remove the cover and have a looksee inside.
Second best would be to jack up the rear and slowly spin the wheel while counting the driveshaft revolutions. A chalk mark on both makes it a lot easier.
Old Apr 3, 2007 | 12:11 PM
emptyd's Avatar
emptyd
Question
Ok, gonna be changing the diff. fluid on Friday - cracking the case open - how do I tell the ratio by looking inside?
Old Apr 3, 2007 | 12:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
It is usually stamped on the ring gear.
Old Apr 3, 2007 | 12:34 PM
phil6608's Avatar
phil6608
hahaha No I don't,,,,good point!
