Dually Conversion Worth It?
Old Apr 3, 2007 | 01:07 AM
bobpearson90278's Avatar
bobpearson90278
Question Dually Conversion Worth It?
I was looking at a JC Whitney catalog and found this: http://www.jcwhitney.com/autoparts/S...sku=BAS786948F
Has anyone tried this? Is it worth it? I have a 1/2 ton Econoline and its pretty unstable on the highway at 80+MPH, It needs some things too. The only set back would be to have something work for a extended fender.
Old Apr 3, 2007 | 06:21 PM
acheda's Avatar
acheda
"JCW Claims:
  • Converts your single rear wheels to dual for increased payload
  • Replacement extension bolt and valve stem extenders sold separately
  • Improves sway control, a must for campers"
The first claim is misleading. All these dual wheels/tires do is increase the payload limits imposed by your single wheels/tires. You still have the limits of springs, frame, and suspension characteristics.
#2 is not even a claim, but a disclaimer.
#3 again, will only take out sway that your tires allow. Most of your sway is probably in your springs.
High-pressure tires (load range E) will probably get you more for your $$$ for less trouble. A real DRW setup has a heavier axle and springs. Your rig probably does not have a full-floating axle or a rear anti-sway bar. Real DRW setups also have the tires spaced equally on each side of the center-line of the bearings, maximizing their load carrying capabilities.
I suggest you put your $$$ into tires, shocks (could be air-shocks to increase load capacity), heavier springs, and anti-roll bars (front, rear, or both). I do not know which of these is most available for your exact rig, but this should give you a starting point.
Old Apr 3, 2007 | 10:37 PM
bobpearson90278
Thanks for that. It seemed like a cool idea, a van dually. I will look into beefier tires and suspension components.
