1978 - 1996 Big Bronco
oil pressue gauge/missing also
Old Apr 2, 2007 | 07:33 PM
RA81222's Avatar
RA81222
I have had this problem on and off.Usually during the warmer weather and stop and go traffic my oil pressure drops and gauge bounces around a bit and then when I take off it goes back up and stays steady.I have had this simialr problem with my battery gauge when runnning my lights and heater on.Any ideas.Driving it today, it ran fine comeing home from work,got in to get the boy at school an hour later and it started to miss.Worse at idle and lower speeds and when going up hills.Wonder if a bad plug wire?
Old Apr 2, 2007 | 07:48 PM
Aciancio's Avatar
Aciancio
first check your oil level. I had a company chevy that would do that when the oil got low.
Old Apr 3, 2007 | 04:20 PM
RA81222's Avatar
RA81222
oil level full-thanks
Old Apr 3, 2007 | 09:26 PM
Aciancio's Avatar
Aciancio
ok next set questions. what engine, how many miles, what kind & weight of oil, and how long have you had the truck and how often do you change the oil
Old Apr 5, 2007 | 06:36 PM
RA81222's Avatar
RA81222
93' 302 127,000 miles.Oil change no more than 3000 miles apart with 10w-30 bought it used 3 1/2 years ago. with 72,000 miles.
Old Apr 8, 2007 | 04:50 AM
christop43's Avatar
christop43
Plug wire or coil wire would be my guess.
