1978 - 1996 Big Bronco
Front Left wheel clunking!!!
Old Feb 21, 2002 | 06:56 AM
90EBBronco's Avatar
90EBBronco
I have a 90 with a 351. I have been having problems with my rear driveshaft lately and so I took it off to rebuild it. I am now driving on my front wheels. Since I took off the rear shaft I have been noticing that my left front wheel is clunking sporadically. What the heck? I pull the wheel, hub and rotor last night and checked the bearings (which I just repacked about a month ago) and they looked fine. Is my transmission going kaput? Any advice would be great!
kevin
Old Feb 21, 2002 | 02:27 PM
93EddieB's Avatar
93EddieB
Is it just doing it in the turns? Basically it wasn't designed to be driven in front wheel drive on the street. You may be getting too much traction in the turns and binding the front end.
Just my opinion though and you know what they say about those.
Rob
Old Feb 21, 2002 | 03:35 PM
brncobilly's Avatar
brncobilly
I also have a '90 Bronco. I also had the same problem the spline on the half shaft is striping,:-(
I had mine replaced about a year ago with up-graded parts and it has been fine sence.
Although, word of advice you shouldn't drive on the front only it is extremely bad for the trans case, keep it up and you will be replaceing that also.
Bill
Old Feb 22, 2002 | 07:29 AM
90EBBronco's Avatar
90EBBronco
Where is it stripping at? I parked the beast last night and am not going to move it again til I get that centering bearing for the rear driveshaft. Do I have to go to a dealer to get a new half shaft? I have never done a spline before so any advice on the procedure would also be helpful. Thanks for the advice and info.
Kevin
Old Feb 23, 2002 | 09:30 AM
Escopeton's Avatar
Escopeton
Post Front Left wheel clunking!!!
I had my 84 do the same kind of noise, too. I finally had to take off the spindle from the knuckle and found the spindle bearings were dry and rusted. After repacking the spindle bearings the noise is gone. Hope it helps. Thomas.
Old Feb 27, 2002 | 07:31 AM
90EBBronco's Avatar
90EBBronco
I quit driving on the front driveshaft and the noise stopped (probably because I wasn't driving but who cares). I replaced the ball and bearings from the forward part of the double cardan joint for relatively cheap ($60) and reassembled the rear drive shaft yesterday. It has fixed the problem and for now the bronco is back in business.
Thanks for replies!
KJ
Old Feb 27, 2002 | 07:36 AM
90EBBronco's Avatar
90EBBronco
