fuel pump + timing chain
Old Apr 2, 2007 | 12:01 PM
Ford347's Avatar
Ford347
I have a 78 302 i need to know if you can change from a 1 peice fuel eccentric to a 2 peice and if a double roller tming chain would fit on as well?
Old Apr 3, 2007 | 06:46 AM
cujo8's Avatar
cujo8
I do not believe there there is a separate eccentric for the fuel pump, but it is driven directly off the cam shaft. A double roller timing-set will fit just fine on a 302.
Old Apr 3, 2007 | 06:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are already two camshaft fuel pump drive eccentrics on your 302 engine, an inner and an outer. If you see only one, they could be stuck together.
D0AZ-6287-A .. Camshaft Fuel Pump Drive Eccentric~Outer
D5AZ-6287-B .. Camshaft Fuel Pump Drive Eccentric~Inner
Old Apr 3, 2007 | 09:04 PM
Ford347's Avatar
Ford347
Thanx for the info I plan on changing my timing chain soon so I want to know first before I buy.
Old Apr 3, 2007 | 09:06 PM
Ford347's Avatar
Ford347
I also need to know if a 9 index crank sprocket whould fit on my crank with just the one keyway
Old Apr 3, 2007 | 09:53 PM
petes79f150's Avatar
petes79f150
The '72 and older 302 used a 1 pc. eccentric. '73-2001(02?) and fuel injected 351 use 2 pc.
There are 2 different timing sets for the 302. Cloyes part #'s:
9-1135. '62-3/21/84 (221,255,260,289,302,302HO,351)
9-1138. 3/21/84-'02 (5.0 & 351)
The cam sprockets are different.
Pete
Old Apr 4, 2007 | 08:36 PM
Ford347's Avatar
Ford347
I was looking to buy the ford racing multi index double roller timing set would this part fit?
