driveshaft vibration?
Old Apr 2, 2007 | 06:15 AM
custom cabby's Avatar
custom cabby
u joint broke on test drive and i think i did some damage to it. at higher speeds i get more vibration but at lower speeds no vibration at all. could the shaft be slightly bent or could it just be the angle is incorrect?
Old Apr 2, 2007 | 10:28 AM
Redcat Diesel's Avatar
Redcat Diesel
If the vibration wasn't there before the joint broke you have a couple things to look at.First off if your truck has a 2 piece shaft make sure the u-joints are in phase.This means that the caps of all 3 joints have to be on the same centerline. This is probably the most common source of a vibration after a u-joint replacement.Second thing if you have the u-joints in phase or have a 1 piece shaft it is possible that it's bent.Take the whole shaft to a driveshaft shop and explain what happened.They will put it in a lathe that will show if or what is bent.If you have the 2 joint shaft make sure to take both sections.I've seen several cases where both sections were damaged from a u-joint failure.As far as angle is concerned, do you have a lift kit or other mods that may have changed the angle? If not it's probably not an issue. Hope this helps.
