Mel
Old Apr 3, 2007 | 09:55 PM
46yblock's Avatar
46yblock
The 1956 Truck shop manual shows the following stats for that year's 332:
CR 7.6:1
Torque 316 @ 2100-2700
HP 200 @ 3800
Only 272s are listed for that year, and of the three models listed the best numbers are:
CR 8:1
Torque 260 @ 2400
Hp 167 @ 4400
Old Apr 13, 2007 | 02:20 AM
kbart71's Avatar
kbart71
hey 46 a side question do you have any data for transmission gear ratios for the 164 series N-700's with the 5 speed transmission (non overdrive) ?????
could use the gear ratios for 1st thru fifth and if you have it the high and low ratios for the rear end as my Motors manuals are not here with me
Anything you have I would appreciate
Old Apr 13, 2007 | 10:25 AM
46yblock's Avatar
46yblock
Here is what I can find, but only have a 1956 manual which is scattered since its pages separated from the binding some years ago:
5 speed medium duty, direct drive 5th gear: 7.08, 4.09, 2.38, 1.47, 1.00
5 speed heavy duty, direct drive 5th: 7.58, 4.38, 2.40, 1.48, 1.00
The heavy duty is listed for only F-750, B-750, and C-750. The medium duty was found in those same models, plus a big group from 600 & 700 series.
Nothing is available here on the rear ratios. Hopefully someone else with more info and an updated manual will help out.
Old Apr 18, 2007 | 09:39 PM
adharvey2's Avatar
adharvey2
kbart71, if you have your axle code I can look up the ratios for you. Also they are stamped on the top of the carrier. Your transmission is likely a clark 250 if your original engine was a 292. Can't find ratios for it though. There is absolutely no question that the engine in your gallery photo is a HD332, also known as a "332 industrial" (probably to avoid confusion with the car 332FE) , and the "lincoln Y". You'll need a HD302 or HD332 bellhousing to make it work. It would have been an option for your N700. The 292 bell will not bolt to it.
Old Apr 19, 2007 | 04:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1963 N-700's had 6 different rear axle options...I have all the ratios for all the rear axles, what rear axle do you have?
Ford did not rebuild any engines. Tomador Engine Co in Los Angeles rebuilt all the engines (and everything else) for Ford from the 1950's thru the 1990's for distribution in the 11 Western States, Alaska and Hawaii. Tomador was also known as Genuine Parts Distributors (GPD). GPD had a contract with Ford, their packaging reflected Ford, their parts were sometimes bought from Ford, but GPD was not owned by Ford.
Mercury Marauder Y Blocks? Since when? No such animal, because no Marauders were made till the early 1960's, and all had FE engines. During the mid to late 1950's, there were other Lincoln-Mercury Y blocks. The 317 of 1954 became the 341 of 1955, then the 368, then the 383, and last, the 430. Don't assume you have a 430, a 383 looks identical. The factory 3 duece set up and aluminum valve covers were used on 1957/58 Mercury Turnpike Cruisers, and optional in the Parklane Series. 1957 TP Cruisers had a 368, 1958 had a 430. 1960 Mercs had either a 383 or a 430. Just to make things more confusing, the 430 was dropped in 1966 and replaced for a short time by a larger version, the 462.
The Edsel 361 FE and Y block 410 were only used in 1958. There also was no such thing as M-E-L till 1959. The Edsel Division was formed in 1956 to produce the E-Car which became the 1958 Edsel. Most of the engineers, stylists and even the president of the Division, James J. Nance had come over from Packard, which folded in March 1956. The 1958 Edsel was a complete sales flop. The Edsel Division was soon disbanded and the remnants were folded into the Lincoln-Mercury Division in the fall of 1958.
Old Apr 19, 2007 | 03:12 PM
kbart71's Avatar
kbart71
holy piston shafts bat man thats a lot of information to digest (still waiting on numbers for engine and rear etc. ) e-mailed home to get them the other night have not had a response yet but i will definately post them here when i get them although at this rate I'll be home to check them for myself first. I appreciate everyones help here has definately made me think
BART
Old Apr 19, 2007 | 07:20 PM
adharvey2's Avatar
adharvey2
It's tempting here to get into a lengthy discussion about MELs, but the fact of the matter is that this is a truck site and MELs never had the remotest thing to do with trucks, not even pickups. By the time the MEL came out Ford was only two years away from introducing the super duty engines for heavy trucks, the 292 was doing just fine in the light and mediums trucks, and the Lincoln industrial could fill in between until the FTs came out in '65. The MELs earned their keep throughout the 60s in Lincolns and T-birds (and Mercurys?) until the early seventies, when they were replaced by the 460.
Anyway Kbart71 maybe you should start a thread on Lincoln industrials since you apparently now own one.
Old Apr 19, 2007 | 07:49 PM
kbart71's Avatar
kbart71
good point Lincoln industrial EH,,,, Will see about starting a new thread shortly after I post the Block casting numbers and confirm what this thing is (guess it's a classic example of Buyer beware )
Old Apr 22, 2007 | 10:44 AM
59flatbedford's Avatar
59flatbedford
all right what exactly is a mel. im kinda confused now
Old Apr 22, 2007 | 11:32 AM
arctic y block's Avatar
arctic y block
Talking
I hate to admit it but i'll second that.
Old Apr 22, 2007 | 03:11 PM
kbart71's Avatar
kbart71
no kidding What is a MEL so far it's Not a y block and it's not an FE or a windsor or a modular engine obviously , definately not a 300 six cylinder , Maybe a MEL is a peice of Alien technology go figure .............It's a goverment conspiracy to confuse Goofy Rednecks like myself....... (ok sorry had to throw in the government Conspiracy and alien technology part just needed said)
Old Apr 24, 2007 | 11:28 PM
adharvey2's Avatar
adharvey2
An MEL (Mercury-Edsel-Lincoln) is a Ford engine family that is most commonly represented by the Lincoln 462 of the sixties and early seventies, but they actually came out in 1957 or 1958 as the Mercury 383, Edsel 410, and Lincoln 430. In cars, they replaced the car versions of the Lincoln Ys that we've been discussing (341, 368, etc). They're big, high compression torque monster engines with alot of unusual design features. They're roughly contemporary to the FEs, and share the same bellhousing pattern (with some exceptions).
There's more here:
The (MEL) 383, 410, 430, 462 Engine Forum
Old May 3, 2007 | 02:26 AM
  #28
Bessie's Avatar
Bessie
Mike, the 430 MEL in my 56 F350 sitting in my driveway still has your name on it. If you want, send me a PM and I'll give you the address if I have'nt already - feel free to stop by and pop the hood for a picture or two. Also, there is an engine manual in the glove box. I intend to get down that way sometime this month!
Brian
Old May 9, 2007 | 02:53 PM
  #29
KULTULZ's Avatar
KULTULZ
Post
...no Marauders were made till the early 1960's, and all had FE engines.
The term MARAUDER was first used describing the MERCURY 383 and 430 in 1958.
The last year for the passenger car LINC Y-BLOCK was 1957. The 383 and 430 were members of the MEL Engine Family.
Even use the same block, heads and intake.
The 1958 MERCURY SUPER MARAUDER OPTION included cast aluminum rocker covers as an additional option only. The engine was available across the board (MAR 1959) as well as in the 58 LINC whose option did include brite rocker covers.
The 1957 MERCURY TPC offering was the LINC 368 rated @ 290HP. A dual four barrel version (M-335) was available in the TPC and other models and was rated @335HP.
The 361 was also used in the 59 EDSEL. The 410 was a member of the MEL Engine Family.
In the middle of 1958, FORD MOTOR COMPANY decided to combine the operations of MERCURY, EDSEL, LINCOLN and the ENGLISH FORD lines to create a new MERCURY-EDSEL-LINCOLN Division. The group was headquartered at 3000 Schafer Road in Dearborn, MI which was formerly LINCOLN Division headquarters (CONTINENTAL actually).
The new organization, under the control of James J. Nance (the former President of PACKARD), was responsible for engineering, manufacturing and marketing of MERCURY, EDSEL, and LINCOLN cars, plus the marketing of ANGLIA, PREFECT, CONSUL, ZEPHYR and ZODIAC passenger cars and the THAMES van trucks.
-55 Years of MERCURY
John A. Gunnell
On November 19, 1959, Ford discontinued the Edsel marque and the final car rolled off the assembly line by the end of the month. MERCURY was combined with LINCOLN to form the LINCOLN-MERCURY DIVISION.
Old May 9, 2007 | 07:08 PM
  #30
46yblock's Avatar
46yblock
Bessie, PM sent.
Mike
