97 F-150 4.6 Liter engine
Hey everyone, I have a huge problem. My truck is running like crap. It is a 97 F-150 with 167,000 miles on it. I changed plugs and wires about 20,K ago. I got to checking plugs and wires and got to the second cylinder back on the drivers side and found it had antifreeze in the spark plug cylinder, causing the plug to groung out. I borrowed a Stant preasure tester from my buddy but didn't have the right adapter for the preasure bottle. My question is has anyone had this problem yet, and if so what was the cause? (intake gasket, head gasket?) I could relly use some info. Any help would be greatly appreciated.
Thank You
Thank You
Here you go:
http://www.geocities.com/brokedown.ford/ford.pdf
exploded view with numbers and descriptions.
