Front End Shake
Old Apr 1, 2007 | 07:34 AM
ozark1's Avatar
ozark1
Cool Front End Shake
When returning home yesterday...on pavement...all of a sudden the front end...84 F-150/Auto/2WD..started shaking...out of the blue at 35 mph..Stopped to check tires..Timberland...31 in.....500 miles...no sign of trouble...Back on road...again at 35. I have been driving this truck occasionally for 6 mos. Now This.....Any Thoughts?...Jv
Old Apr 1, 2007 | 07:55 AM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
I would check 2 things first. 1) If I understand your post right there new tires so maybe the installer didn't get the weighs on right during balancing and you lost a weigh or 2) Check the tie rod ends one could be going bad. That's the first things I'd check
Old Apr 1, 2007 | 12:00 PM
Franklin2's Avatar
Franklin2
I would jack up each wheel and try to move the wheel vertically as well as horizontally to check for play. I would also make sure the shock absorber mounts on both ends is tight.
Old Apr 1, 2007 | 06:02 PM
big hoss 29's Avatar
big hoss 29
One more thing to check is your radius arm bushings. They may be shot and letting the front end to shimmy around.
Old Apr 3, 2007 | 06:33 AM
ozark1's Avatar
ozark1
Smile
VERDICT.......Tie rod end...Replaced both...Did not know the steering could be affected as much as it was. The.."wander"..is gone, and the truck drives much better. Wish it worked on the mileage of the HO as well...........j
