Oil & Lubrication
help
Old Apr 1, 2007 | 07:13 AM
confederate_mudder's Avatar
confederate_mudder
help
I just installed a mechanical oil pressure gauge in my 79 f150 4x4 and its reading 60 psi no matter if its idleing or im driving down the road. is this bad for the truck?
Old Apr 1, 2007 | 07:21 AM
Kep4's Avatar
Kep4
Jäger
Did you install an aftermarket hi-pressure or hi-volume oil pump? Does the psi build gradually when you start the truck or does it sweep immediately to 60?
I believe there should be some variation between idle psi and 2000 rpm+ psi.
Not sure how 60 psi would be bad for the engine, unless the gauge isn't reading properly.
Old Apr 1, 2007 | 07:29 AM
confederate_mudder
I just bought the truck a few days ago but from what i was told i dont belive theirs any upgraded oil pump.
it goes straight to 60 as soon as i start it up.
Old Apr 1, 2007 | 10:17 AM
arctic y block's Avatar
arctic y block
By mechanical gauge do ya mean it has a plastic oil line running to it or electrical wire? I ask this because some folks call all after market gauges mechanical. If electric I would say that the sending unit is bad. Take wire off sender and ground it. This will peg the gauge high if the gauge is good. If it has an oil line than I would again suspect the sending unit. It could also be that someone has chanced out the sender and it is wrong for the gauge. But this should only give you a false reading and the gauge should still change do to RPM.
Old Apr 1, 2007 | 01:17 PM
pbjohns's Avatar
pbjohns
If it has the oil line, you won't have a sending unit, just a fitting to connect in to the oil passage to the back of the guage. With the oil line type, the pressure will very depending on the rpm, idle = low value, increase rpm= higher value.
Old Apr 1, 2007 | 01:23 PM
vettdvr's Avatar
vettdvr
My guess is it is an electric gauge with the black wire going to the engine block vs. the pressure sending unitl. It could be a direct reading gauge with the oil line going to the engine block, but my guess is that it isn't. Jim
Old Apr 1, 2007 | 04:03 PM
confederate_mudder
its a mechanical gauge with the oil line coming from the gauge threw the firewall to the engine i put it in place of my old sending unit. what could be causing this reading?
Old Apr 1, 2007 | 05:08 PM
arctic y block
Ya might try burping it. Break the line loose at the gauge and let the air out. Have a wad of paper towels handy.
Old Apr 1, 2007 | 06:30 PM
confederate_mudder
thanks for all the help the gauge works great now!
Old Apr 1, 2007 | 06:33 PM
arctic y block
So what was the problem? What did ya do to fix it?
Old Apr 1, 2007 | 06:36 PM
confederate_mudder
i burped it as you said to do and reconnected it now it works properly. thanks again
Old Apr 1, 2007 | 06:37 PM
arctic y block
Good glad I could help.
