You asked for it...my codes.
Old Mar 31, 2007 | 10:10 PM
kkamann's Avatar
kkamann
Based on your recommendations, I went to local Autozone and had them hook their iPod up to my truck.. You folks said you would help me out with any codes. 96 Exp XLT, 4.0 V6, 4WD. So here they are...
P0401 (Insufficient Flow something something)
P0420 (O2 sensor)
I bought a new IAC due to the warm startup stalling issue that everyone else seems to also have. I will be installing it tomorrow.
Can you please EXPLAIN what these codes mean, if they are serious, can a novice like me fix, etc. Also, will the new IAC help/fix with the P0401 issue?
Thanks,
Kaman
Old Mar 31, 2007 | 10:25 PM
aquanaut20's Avatar
aquanaut20
P0420 (O2 sensor)
Thanks,
Kaman
http://rockledge.home.comcast.net/Ra...llery/DTCs.pdf
read page 14-15,
This is what you will be looking for
http://groups.msn.com/RangerBill/ran...to&PhotoID=677
This is how you will test,
http://rockledge.home.comcast.net/Ra...tage-Test.html
This is how it works in the system,
http://rockledge.home.comcast.net/Ra...dEGRSystem.htm
Good luck, let us know how you made out.
Old Mar 31, 2007 | 10:31 PM
aquanaut20's Avatar
aquanaut20
the P0420, (read bottom of page 16) could be set by the misfire so wait until you have that cleared.
Old Mar 31, 2007 | 10:40 PM
kkamann's Avatar
kkamann
This says to perform a KOER self-test. How do I do that?
Also, is this a serious problem, other than destroying the planet? It looks like my emissions will have more icky stuff coming out.
I can clear the codes by disconnecting the battery, correct?
Old Apr 3, 2007 | 04:56 AM
marragtop's Avatar
marragtop
Yes, you can clear the codes by disconnecting the battery for at least 5 minutes.
Old Apr 3, 2007 | 07:29 AM
patho44's Avatar
patho44
or if you dont want to have to reset all you radio stations, just pull the fuse for the pcm.
Old Apr 3, 2007 | 08:33 AM
kkamann's Avatar
kkamann
Good tip patho...hadn't thought of that.
