Fuel Gauge quit working
Old Mar 31, 2007 | 08:55 PM
wyazel1's Avatar
wyazel1
Well I just got my trucks electrical all sorted out, signals, tail lights etc...and now the dam fuel gauge has quit working. Its just stuck on E. Any advice where to start?
Old Mar 31, 2007 | 09:01 PM
Franklin2's Avatar
Franklin2
See if you can get to the fuel tank where the sending unit is. Take the wire off, and with the key in run, touch the wire to ground. The guage should swing full scale one direction. Then take the wire off ground and let it hang in the air. The gauge should swing full scale the opposite direction.
If the above test works, the wiring and the gauge are good, and there is something wrong with the sending unit.
Also make sure the sending unit itself has a good ground, don't trust the tank straps for a ground.
Old Mar 31, 2007 | 10:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Once you get finished with the electrics, check the actual float on the fuel tank sending unit. The float is composed of two pieces of copper soldered together. Solder breaks down, gas seeps in, float sinks to bottom of tank. There's also a filter screen on the pickup tube that after 30 years will need replacing too.
C0AZ-9202-A .. Fuel sender float
D1AZ-9A011-A .. Fuel sender screen (filter)
C1AF-9276-A .. Fuel sender gasket~to tank
Eicca
17
Jul 9, 2014 08:22 PM
Gregtg
2004 - 2008 F150
Dec 4, 2013 11:04 PM
miller_feed
1983 - 2012 Ranger & B-Series
18
Oct 13, 2010 08:50 AM
toddncandy
Nov 18, 2005 07:36 AM
scootin
Dec 22, 2003 06:08 PM
