Gauges
When I turn the temp controls on oil&water readings increase,turn on the fan each position readings increases until maxed out, also when I turn the lights on the readings increase.
wires look to be in good shape.TIA
Several gremlins could be at work.
Round One: Behind the dash, plugged into the printed circuit is the CVR = constant voltage regulator. This device regulates flow of electricity to the gauges. When it fails, the gauges fluctate wildly. Take care removing the CVR, that you don't tear the printed circuit board.
Round Two: Corrosion on the terminals of the printed circuit can also cause the problem. Mi1lion is the guru on this (and many other things) here at FTE. Besides excellent advice, he can post pictures. Very helpful..as usual.
D1AZ-10804-A .. CVR (Motorcraft GR-513)
