how much paint do I need
Old Mar 30, 2007 | 11:35 AM
marioc956's Avatar
marioc956
Ok I know this a ford truck forum but a new project came up and wanted to know if you guys can help me out. I have a 1987 honda crx I want to paint how much paint would I need to paint this car The car has plastic molding half way down the body that we are going to paint a different color so the top half is what Ill need more paint for I also want to paint the inside of the door jambs and whatever else that need to be painted inside.
Old Mar 30, 2007 | 04:50 PM
Indy_Gearhead71's Avatar
Indy_Gearhead71
Since you're making it a two tone car, I'd go with a quart of each of the basecoat colors ( when you add the basemaker it will make 2 quarts of each, more than enough ). For the clear, it's cheaper to buy a gallon than it will be a couple quarts and possibly run short in case problems arise and you need to re-clear a panel. You'll also need a couple quarts of primer, depending on whether or not you use a 2 part epoxy or just a filler primer.
