Tach?
Old Mar 30, 2007 | 10:50 AM
bobfromktown's Avatar
bobfromktown
Tach?
I got a 95 f150 302 v8, wondering if i can buy a tachometer and somehow hook it up to my truck , im talking about one like at autozone or something , i have an automatic transmission i just want to know my rpms, and my truck doesnt have one.
Old Mar 30, 2007 | 10:58 AM
fbama73's Avatar
fbama73
If you want to, you could go to a junkyard and get a factory instrument cluster with the tach. From what I've heard, the trucks without it have the wiring harness for the tach. I can't confirm 100%, as my truck has the factory tach.
Old Mar 30, 2007 | 11:03 AM
bobfromktown
yeah, I just wanted to put a tach on there, so your not sure if i can even put one on ,if it didnt come from the factory.
Old Mar 30, 2007 | 11:09 AM
92F150Flare's Avatar
92F150Flare
yep.......you can hook any of those at tachs up as long as it's for an 8....and most are. Just figure out a place to mount it and run the wires to your coil.....negative side I think.....should be instructions with the tach. Some mount them in A pillar pods.....some on the dash......some on the wheel
Good Luck
Old Mar 30, 2007 | 11:15 AM
bassproguy07's Avatar
bassproguy07
I coulda told you that....go get you a little autometer like cody has in his truck....cheap and small we can mount it on your pillar or on top of the dash. we could probably do that today if you wanted...take like 20 minutes at the most
Old Mar 30, 2007 | 03:25 PM
lostin90s's Avatar
lostin90s
you can hook up any tack . or get factory one for your truck it will plug right in . You will need a 94 -95 guage cluster for it to work in your 95 . And it will look less cluttered in truck .
Old Mar 30, 2007 | 05:55 PM
bassproguy07
ok s we just have to get to the stock tachometer connection and then were set.....
Old Mar 30, 2007 | 05:58 PM
andym's Avatar
andym
All trucks are wired for tachs, some of them just didn't have the gauge installed.
Old Mar 30, 2007 | 06:09 PM
vols_fan22's Avatar
vols_fan22
i acutally have a factory instrument cluster with the tach for a 94-96 model with 8 cylinder here at my house if you are interested in buying it and also u can check on ebay for one also but sometimes they seem to be a little expensive. if you are interested in it email me or send a private message
Old Mar 30, 2007 | 06:36 PM
bassproguy07
no offense to the factory instrument cluster but an after maret tach mounted on the pillar and lit up with some blue lights is way cooler than stock haha just my 2 cents but its bobbys truck not mine lol
Old Mar 30, 2007 | 06:55 PM
vols_fan22's Avatar
vols_fan22
its all in apperance and preferance but it would look much cleaner with a factory instument cluster that has a tach just my opinion
Old Mar 30, 2007 | 07:12 PM
preppypyro's Avatar
preppypyro
Im not much for aftermarket tachs and the way they look. I havent seen the pillar mounted ones though,that may be ok, but the big bulky ones just dont appeal to me.
