exhaust size
Old Mar 29, 2007 | 10:55 PM
digger190's Avatar
digger190
exhaust size
i have a stock 6.0 and was wandering if a 5'' turbo back exhaust would be ok or should i go to a 4". thanks
Old Mar 30, 2007 | 08:37 PM
digger190's Avatar
digger190
20 veiws and no responders wow.
Old Apr 2, 2007 | 09:21 PM
jimdandy's Avatar
jimdandy
Possibly no one has done this particular modification, so have no input. Call the tech dept at Banks. They should be able to help you.
Also, see if the following is of any help:
http://www.ssd4u.com/streetsmart_082.htm
jd
Old Apr 9, 2007 | 09:20 PM
IDMooseMan's Avatar
IDMooseMan
I have a '97 with the 7.3l diesel. Unless you're going mega-horsepower, 5" pipes from the turbo back might be more than you need.
Do like jimdandy suggested...call the exhaust manufacturers you're interested in and see what they recommend for your application.
Old Apr 14, 2007 | 06:39 PM
bruno6491's Avatar
bruno6491
hey
hey,
I just bought a 5" cat-back system and i am just running a superchips tuner. I think i went with the 5" just to say i have a 5" exhaust witha 7" tip, yep thats right, 7" tip. I will be getting it in about a week or two and will compare to see oon hp gain and what kind of sound i get
Old Apr 17, 2007 | 10:04 PM
eco's Avatar
eco
Depends on what your goals are. The engineers picked the stock size for a reason. Do you have more credentials than they do? If so, second guess them and put on a different size. If not, leave it the way it is.
Old Apr 18, 2007 | 07:51 AM
dkf's Avatar
dkf
Give me a break, the only reason the truck comes from the factory with the tiny pipes is to save $$$. Bigger tubing costs more money and when a company is trying to make as much money as possible performance takes a back seat. Another major concern for the factory is they want to make a quiet truck for prudes who want a truck that drives and sounds like a car.
The 5" exhaust for your 6.0 is reccomended to be used with a tuner (High HP and Torque) and a high flow intake. A 4" should suit you fine even if you decide to add an intake or tuner in the future. There are guys around here that run pipes bigger than 5".
Old Apr 18, 2007 | 08:20 AM
bassproguy07's Avatar
bassproguy07
What is stock on the 6.0, 3 or 3.5?? I saw one driving down the road the other day that had a 5 inch system, and man was it mean lookin. He also had like an 8 inch tip. Down here in Texas, bigger is always better but thats just some of the gus preference.
Old Apr 18, 2007 | 02:10 PM
eco's Avatar
eco
Yes, but we are talking about a stock truck.
The stock tubes are perfect considering the powerband of the motor and the exhaust gas velocity to match. Go bigger, you lose low rpm torque unless you adjust the motor to match the larger tubes.
Old Apr 18, 2007 | 06:34 PM
dkf's Avatar
dkf
Diesels DO NOT need backpressure in the exhaust. Gas engines need some backpressure for exhaust "scavenging".
If the stock exhaust is perfect why can a significant gain be had by just swapping out to a 4",5" or 6" system without touching the computer.
