Oil & Lubrication
Oil filter relocation...
Old Mar 29, 2007 | 09:42 PM
eco's Avatar
eco
If I were to relocate my filter in a location that is elevated from the factory location does that mean that when the vehicle is turned off all the oil in the lines will run back into the motor causing the oil system to run dry upon start up untill the lines are filled up with oil again??
Old Mar 30, 2007 | 12:33 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Not if you run a filter with an oil anti-drainback valve.....
