while the engine is out of my truck, I thought it might be a good idea to go ahead and replace the clutch and slave cylinder. the slave is the internal type. So replacing either requires transmission removal.
My question here is regarding the clutch, I pulled a dual disc (original) clutch out of the truck.
Now checkers quotes me 180 bucks, and NAPA asks if it's dual, then quotes me about 400
can I use a Centerforce II clutch setup, or do I HAVE to use the dual disc type???
