1978 - 1996 Big Bronco
Window Maintenance?????
Old Mar 30, 2002 | 09:33 PM
Tetchy101's Avatar
Tetchy101
Where exactly does a person lube to keep the power windows in the doors and the tailgate in good working order. Can you describe the location and what it looks like and maybe where I can find a step by step how to do it. Im not too familiar with window tracks.
Tim
Old Mar 30, 2002 | 10:17 PM
Bob_VT's Avatar
Bob_VT
Spraying the window gasket tracks that the window rides in with silicon spray and I also smear some grease on the gears (regulators) inside the door panels. I do the same on the rear window and it appears to make a difference. At times the rivets (cheap rivets AKA Ford Better Idea) that hold the window assemble inside the door panel tend to work loose. Just drill out the loose ones and replace them with short bolts. This will keep the assemble tight and aligned.
Bob
Old Mar 30, 2002 | 11:06 PM
rebelford's Avatar
rebelford
