Exp 98-'00???
Old Mar 27, 2007 | 11:40 PM
kitebuz's Avatar
kitebuz
Exp 98-'00???
I am recently (& unexpectedly) on the used car market after getting rear ended in my car & the insurance company is writing it off. I am thinking about replacing it with an Expedition.
I've been reading about the '98's-'00's, and just trying to figure out the differences. Price wise, it's looking like '98 or '99, and I can't see there was a ton of change in these model yrs. Anything I am missing? Is one preferred over another?
A couple specific questions:
- was the air suspension available in '98 as well as '99? I am a bit confused on the differences in air suspension/auto-level offered on the 4x2 vs the 4x4. Does the suspension self adjust (or manually) on the 4x4 depending on load, or is that just the 4x2? I will do some towing, so like the idea of air bags to level it out - is it a good option, or prone to problems?
- what year did the auto-climate control become available, and was it only on the Eddie Bauer versions?
Thanks for any insight.
My other vehicle is a Ford Excursion, which I love, but, somehow, my wife has mostly commandered driving it
Old Mar 28, 2007 | 10:19 AM
buzzard's Avatar
buzzard
'99-'02s are definitely the best looking.
PI heads were introduced in '99 and give 30 or so more HP so I wouldn't consider any older models. As for the air suspension, do a search, it's one of the most talked about topics around here....and problem prone.
Old Mar 28, 2007 | 01:12 PM
kitebuz's Avatar
kitebuz
I'd have to agree w/ you on the looks.
PI - 30hp is nice, but not if at the risk of a leaking head gasket:
https://www.ford-trucks.com/tsb/full...php?tsb=03-6-2
Has this been a problem for alot of the '99-'01's? If so, I'd forego the extra power in favor of one less (big) thing to service and stick w/ a '98. If not a big deal, I'm all for extra hp.
I asked on the air suspension b/c I read alot of contradictory/unclear statements in regards to what is offered on the 4x2 vs 4x4. Seeing if someone could give a definitive reply - believe me, I've been enjoying searching & reading here. I guess I could always just install an aftermarket set of bags, and be done as well.
Another question - on the '98 & '99's - what is the story with 2wd vs AWD - was the AWD an option, or just available on certain models or yrs? I think I would prefer plain old 2WD, w/ 4H & 4L to save on mileage and complications - or is the AWD that much better? Can you manually over-ride it to 2WD?
Thanks for any replies to all the questions.
Old Mar 28, 2007 | 02:01 PM
99ExpyProblems's Avatar
99ExpyProblems
You could "what if" yourself to death. The most important thing is not simply buying a newer model vehicle, the important thing is getting the luck of the draw.
You never know how the person before you cared for their vehicle. The most important thing about a used vehicle is whether or not the person performed routine maintenance. Oil changes every 9k is HARDLY a reason to think you'll do better with a 2000 model, than a problem prone 97 or 98 or 99.
Good Luck in your hunt!
Old Mar 29, 2007 | 07:26 AM
c_hohensee's Avatar
c_hohensee
As far as the type of 4wd the 98 has 2hi A4WD 4hi and 4lo. In 2hi you are indeed locked out of 4wd. In A4WD it only engages when rear wheels spin so technichly (spelling) you could leave it in this position for most of your road driving. The other two options are for non-pavement use.
On the air suspension I installed the airlift bags with an onboard inflation system and have been happy with that.
Old Mar 29, 2007 | 10:04 AM
PaulC's Avatar
PaulC
On air suspension: If it's a 4x2 the air suspension was rear suspension only. On 4x4, the air suspension was found on the front and rear.
Auto climate control was available since the Expedition's inception, but was limited to the Eddie Bauer, at least during the '97 to '02 model years.
Old Mar 29, 2007 | 11:57 AM
kitebuz's Avatar
kitebuz
Thanks for the clarifications.
I also agree prob the single most important issue is what kind of previous owner (s) maintained the vehicle.
As soon as I am done w/ the ins. co., I will start looking hard.
Wabronco07
May 7, 2014 10:39 AM
fire3110
May 31, 2011 06:53 PM
96brco
Mar 17, 2011 06:29 PM
who1975
Sep 26, 2003 07:02 AM
xmopar
18
Dec 12, 2002 12:26 PM
