92 Explorer Front end Squeek
Old Mar 27, 2007 | 08:54 PM
Skotty's Avatar
Skotty
I just inherited a 92 Explorer Xlt.This thing is in very good shape and not a scratch on it.One problem i am having is it has sat in a garage for about 6 months and has developed a Squeek when turning corners.I have greased all zerts in the front end but to no avail.You can rock the front end and hear it.Sounds like a bushing or something that has just hardened.Any help would be appreciated.
Old Mar 27, 2007 | 11:22 PM
mrshorty's Avatar
mrshorty
My BII had squeaks like that were in the shock absorber mounts. The best advice I've got is to get someone to come out and bounce while you poke around with a stethoscope until you find the squeak.
Old Mar 28, 2007 | 11:07 AM
mikeinri's Avatar
mikeinri
Most likely a bushing, mount, etc. somewhere. One good tip I've seen is to have someone bounce the truck while you spray each of the bushings with WD-40 (or lubricant of choice). Keep bouncing, if the noise doesn't stop, move to the next bushing. When the noise stops, you've found the source.
Old Mar 28, 2007 | 06:25 PM
Skotty's Avatar
Skotty
Thanks Guys I isolated it down to the right bushing right under the passanger side.Wasn't Quite sure if WD-40 was the Debil or not but ill give it a try
