Offroad & 4x4
Axle Bolt Patterns?
Old Mar 27, 2007 | 08:02 PM
bobpearson90278's Avatar
bobpearson90278
Axle Bolt Patterns?
I'm looking to do a 4x4 conversion on my E150 and am wondering if any of the Dana axles are 5 lug to match my rear 9''. All the axles I have seen are 8 lug. Is there a way to make the Dana 5 lug or an adapter for the rear 9''? Thanks is advance for the help.
Old Mar 27, 2007 | 08:06 PM
PlaidassSurf's Avatar
PlaidassSurf
the dana 44 out of an older 150 or a bronco has the 5 lug pattern your looking for
Old Mar 27, 2007 | 08:12 PM
bobpearson90278
Cool, thanks for that info. Is a Dana 44 as tuff as a Dana 60? I'm trying to build it as good as I can.
Old Mar 27, 2007 | 09:43 PM
MBBFord's Avatar
MBBFord
No it doesn't compare to a D60, but the D44 will handle 35s if you don't keep the skinny pedal on the floor.
Old Mar 27, 2007 | 09:49 PM
MBBFord's Avatar
MBBFord
Double post
Old Mar 27, 2007 | 10:15 PM
westtntrucker's Avatar
westtntrucker
My suggestion would be to find a wrecked 3/4 ton and pirate the intire running gear.
Going to a full floater rear would be a lot better. If you twist an axle shaft, the wheel and tire will not come off. Drop the rear drive shaft, put it in 4X4 and have front wheel drive to get you home on. Would probably be cheaper in the long run. Again, my 2cents.
Old Mar 28, 2007 | 05:25 AM
PlaidassSurf
a Dana 60 is stronger, but good luck finding one, and if you do, be prepared to pay for it. Depending on how much you plan on wheeling and what size tire, a Dana 44 / 9 Inch combo should suffice. westtntrucker's right about going to a full floater rear being stronger. How big a tire were you looking at running?
Old Mar 28, 2007 | 01:16 PM
bobpearson90278
I have a set of 33''s. There in fair shape, I don't want a huge wheel/tire combo, just something to give it a more aggressive stance and be able to have fun with it in a muddy field. I'm still planning all this out, my engine is in rough shape and need to either buy a reman. or rebuild the one I have. Thanks for the posts though, they helped a lot.
Old Mar 28, 2007 | 01:31 PM
PlaidassSurf
you can run 33's all day with a dana 44 ford 9 inch combo
Old Mar 29, 2007 | 12:45 AM
84blackmagic's Avatar
84blackmagic
oh yea easy.. im running 36's on a dana 44 ttb... and 9inch... and i beat the heck outta it.. and i havent had any problems... just remeber to check your gears.. 3:50's or 3.73's would be perfect..
Old Mar 29, 2007 | 02:25 AM
bobpearson90278
Sweet! I found one locally and will check it out, its a '73 out of a Bronco. Now I just need to source a NP205.
Old Mar 29, 2007 | 03:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FYI: The Nissan Titan 4X4 uses Dana 44's front and back. The biggest complaint among these truck owners is the front/rear end. Many have been lifted with other mods. Before considering a Dana 44, it might be worth a trip to titantalk.com to read all about the Dana 44 failures. While the Dana 44 is a reliable axle, it doesn't stand up well to the 300 + HP modded trucks with lead footed drivers.
Caveman2851
May 11, 2015 06:13 AM
FE406
Offroad & 4x4
Mar 14, 2010 11:41 AM
mattjensen
Apr 24, 2009 04:28 PM
mattjensen
18
Feb 2, 2009 11:18 PM
ag30265
18
Jul 29, 2008 12:43 AM
