1978 - 1996 Big Bronco
tranny problems
Old Mar 27, 2007 | 06:58 PM
flipcrashburn80's Avatar
flipcrashburn80
tranny problems
hi i have a 1995 ford bronco with a 4 speed auto trans it wont shift into park with the collum shifter but i can move the linkage on the tranny into park and it will stay and when i shift it will not shift into second or first.is there a way to adjust the cable?
Old Mar 28, 2007 | 05:31 AM
muckypaws's Avatar
muckypaws
There is an interlock on the column so it can't be put into drive unless the key is in running. I'd suspect this is buggered if you can move the MLPS on the box ok.
I can't remember how it all works but an exploded view of the steering column should help. Subscribe to www.alldatadiy.com or get a haynes book?
