Hi guys im sure everyone has been through this before but im losing daylight can anyone help me get this stuck pin out of the bore. Its the top pin with the 3 beveled edges on it not the full round one. Thx anything asap would help.
Just had this experience this weekend. PB Blaster the crap out of it. I ended up putting the bracket back on the truck and put vise grips on the bevel area and just started to try to move it (it wasn't going to budge). Hit it with a hammer to push it in a little more and then I was able to start rocking it back and forth a little. After I was able to rotate it 360 and hammered it out with a hammer and screw driver.
I didn't think it was going to come out myself. ANTI SEIZE it once you start putting it back together.
I did the same thing but the caliper in a vise PB blasted the hell out of it and was able to slowly start working it back and fourth. I might even have used a pipe wrench.
........ANTI SEIZE it once you start putting it back together........
I would not recommend using anti-seize on the caliper pins. It will not hold up to the heat these pins could see and will turn into a very sticky goo. Use only a silicone caliper grease approved for disk brakes and check them often if you live in a corrosive area.
awesome.. guess what I'm tearing apart this weekend to relube. thanks for this information!
Ya i thought anti sieze too but the guys at napa said use the silicon(specialized for disc brake calipers) grease. Passenger side went smooth then drivers i noticed the rubber boot was off on side then i knew is was in trouble If i cant get it off does anyone know what that part is called aside form caliper? so i can price it for a new one. Im not going to destroy it and my time if i can replace the whole thing.
Caliper mounting bracket. I tried just about every approach on mine and i never got it out, then i just put a used but good caliper bracket on it. I ended up trying a different approach by drilling on the pin and that ended up in the garbage.
I just had this problem this weekend. I took mine to work put the pin in the vise grabbed the top of the bracket and tried to turn it on the pin. It finally broke loose. I used alot of PB blast to.
Finally!!!!!!!!!!! I had the bracket and pin in a vice and had that thing so hot i thought it was going to bend on me I was able to work it free. Thanks for the help, note to self DONT let the little rubber boots come off thier slots(thats what caused mine) if you dont its torch time
