Holley Help
Old Mar 27, 2007 | 05:10 AM
project40's Avatar
project40
Holley Help
I rebuilt the 650 double pumper on my truck to fix a leaking secondary pump diaphragm. Problem solved, however, it wants to keep leaking from the fuel fittings. I teflon taped the secondary fitting and I think it stopped leaking now but the primary keeps leaking. I'll have to replace the primary bowl anyways since the PO took a chuck out of the casting around one of the screws and I cannot get it to seal there but it is a very slow weeping leak. It also seems to leak at the flare fittings on the feed line too. Its some crappy old chrome one that is pretty rusty so I ordered a new one to replace it. Any tips for a leak free install? I'm a noob to a carb this big I'm more experienced with the little small engine stuff so bear with me. Thanks for any suggestions.
Old Mar 27, 2007 | 04:47 PM
kermmydog's Avatar
kermmydog
One thing I can suggest is NOT BUYING CHROME. I bought a CHROME THERMO HOUSING. For my 460. I did everything I know and couldn't get it to stop leaking. Finally I threw the thing away bought a cast iron one and never have had any further trouble. If you have CHROME threads on the pipe that could very well be your problem. Just a thought.
