1978 - 1996 Big Bronco
4WD Knuckle
Old Apr 7, 2002 | 02:46 PM
mwellner's Avatar
mwellner
4WD Knuckle
[updated:LAST EDITED ON 07-Apr-02 AT 04:18 PM (EST)]I need a new knuckle (right front side) because one of the fingers that the caliper bolts on to is bent
1) how early can I go since its a 1996
2) can I get this part new? how much?
3) anyone have a leftover one?
4) anybody have a good deal on them?
5) how long of a job is this for the right front side?
its a 1996 Bronco with manual hubs
Thanks
Mike
Old Apr 7, 2002 | 03:35 PM
honney's Avatar
honney
4WD Knuckle
I dunno how early you can go. I can tell you '90 still uses the lame slider pins rather than bolts (which I prefer). So you're probably gonna need a knuckle from '92+, possibly even later than that. As for how long, it depends upon if you've ever done this before. You might as well replace the ball joints while you've got the knuckle off. This page pretty much tells you everything you'll need for this project:
http://www.off-road.com/ford/bigbroncos/tech/balljoint.html
Old Apr 7, 2002 | 03:36 PM
honney's Avatar
honney
4WD Knuckle
