1978 - 1996 Big Bronco
Need Help on changing fuel filter
Old Feb 14, 2002 | 02:16 PM
alpine7572's Avatar
alpine7572
Hey Everyone,
I'm having trouble taking the ends off the fuel filter. There are 2 clips which snap on the filter itself, but the after that, the hoses going in won't come out. I tried pulling real hard and they won't budge. is there somthing I'm missing here.
Thanks
Mike
Old Feb 14, 2002 | 02:30 PM
ecarter50's Avatar
ecarter50
You need a fuel line disconnect tool available from any parts store to release the springs inside the fitting.
Old Feb 14, 2002 | 03:39 PM
Cheap Monster's Avatar
Cheap Monster
If the clips are out then your not pulling hard enough. You don't need a fuel line disconnect tool for the fuel filter. Just be ready for a gush of fuel (i.e. don't be under it and turn away). Grab the ends and pull harder!
Old Feb 14, 2002 | 04:05 PM
adelyser's Avatar
adelyser
Get the disconnect tools. They are cheap and make it much much easier to remove the connectors.
Old Feb 14, 2002 | 05:29 PM
alpine7572's Avatar
alpine7572
Got the tool and it helped alot!! Thanks Guys
Old Apr 5, 2002 | 12:34 AM
SubmarineAZ's Avatar
SubmarineAZ
Hey, I have a 96 Bronco and I don't see any clips for the tool to depress. I bought the tool at Napa.
If I pull any harder, I'm gonna break something.
Any help?
Old Apr 5, 2002 | 09:24 AM
89XLTBronco's Avatar
89XLTBronco
I bought a Fram fuel filter, and mine came with the tool.
Old Apr 5, 2002 | 11:21 AM
honney's Avatar
honney
Up to around '91 no special tools are required. There's just a hairpin clip at each connection which pops out easily and the lines pull off. '92ish+ use many "fingers" internal to the fitting which slip over a lip on the filter and grab. You need a special tool for this to disengage these fingers as you can't really reach them, and even if you could you couldn't disengage them all at once. Look at how your parking brake cables engage in the rear frame bracket - same principle.
Old Apr 6, 2002 | 12:51 AM
SubmarineAZ
I bought a Fram filter too and it didn't include any tool.
Anyone got a link to the tool I need (96 Bronco)?
The one I got from Napa is like a two sided scissor with two sets of round indentions to fit different diameters of connectors. I can't see anything in the lines to depress and the tool isn't helping.
I don't get it, I upgrade to a newer Bronco and the fuel filter is hard to get off but the single belt is a breeze.
Old Apr 6, 2002 | 01:08 AM
honney's Avatar
honney
I'm not *certain* about '96 but I think they might even be considered a/c line disconnect tools. I know Checker sells a pack of 4 (different sizes) for cheap. They should be round, plastic, and have a slit in them so they can spread open to go over the line (and I think they're usually different colors). Once in place you just slide it forward toward the fitting and it'll pretty much do the rest.
Old Apr 6, 2002 | 08:29 AM
AlM's Avatar
AlM
tool we used on our 96 bronco 5.0 is like this one (which is diff on another 96 5.8 i saw my pal work on last year, maybe mine was diff. because we bought the bronco in may 96?):
Old Apr 6, 2002 | 09:24 PM
Rodeojoe's Avatar
Rodeojoe
It is the same tool on the 96. You wont be able to see the clips holding the filter in.
Rodeojoe
Old Apr 10, 2002 | 01:38 AM
SubmarineAZ
that's the tool I have, too. Maybe I'm just not doing it right.
I'll try it again this weekend and see if I can get it.
thanks for the pic.
Old Apr 10, 2002 | 05:53 PM
AlM's Avatar
AlM
[updated:LAST EDITED ON 10-Apr-02 AT 06:55 PM (EST)]Submariner,
Look here for a diy on the filter replacement by Fordman (clap...clap for Fordman!).
Old Apr 12, 2002 | 12:08 AM
SubmarineAZ
Hey thanks! It's like fuel filters for dummies!
I think I was expecting the tool to catch something or push a catch out of the way, not to depress a spring loaded device. I'm sure I'll get it now. Whatever happened to simple hose clamps?
