1978 - 1996 Big Bronco
carb problems
Old Apr 15, 2002 | 10:16 PM
ogredorf's Avatar
ogredorf
carb problems
[updated:LAST EDITED ON 15-Apr-02 AT 11:27 PM (EST)]i have a 81 bronco
i-6
4spd
it seems the retard that owned it before me took off the air pump,
clipped the hot air line to the choke,bypassed the charcol canister
,ran a hot wire from the fuse box to the choke,and to boot spray
painted over the catalyst tag on the core support.
the haynes manual i bought says nothing about any of the systems(go figure).
is there a dated manual or someone that knows how to put this correct
again.
right now its just for normal running
but in the near future its going to get the following
clifford intake
header
edlebrok 500 cfm carb
comp cams 268h cam lifters,springs,locks,retainers,seals,
timing set,push rods
crane rockers
good head job
.030 overbore
and full balancing
and a nv4500 5spd
with 4.11 gears
and bfg all terrains 32x11.50's
etc.etc.etc
any help ?
Old Apr 16, 2002 | 12:47 PM
AlM's Avatar
AlM
carb problems
