Throttle Position Sensor
Old Apr 11, 2007 | 07:43 AM
bennie's Avatar
bennie
Truck is not runing at all now. Going to have it towed to the Ford dealer. Hopefully they can get to the bottom of this issue.
Old Apr 13, 2007 | 04:07 PM
bennie's Avatar
bennie
As mentioned earlier, the truck will not start so I had it towed to the Ford dealer. They called today and said the first problem is the PCM Powertrain Control Module is bad. They also said that there are also 13 or 14 codes behind that but these could go away when a new PCM is installed. They told me the PCM is no longer available from Ford, but they can get one aftermarket and install it for $350.
What is the PCM
Where is the PCM on a 92 F150
Should I try to pick one up from a salvage yard?
Thanks
Bennie
Old Apr 13, 2007 | 04:57 PM
andym's Avatar
andym
You're getting ripped off. If the PCM truly is bad, then there is absolutely no way to know what codes are stored. After all, it's the PCM's job to detect problems and store codes. It is the brains of the engine. It monitors all the sensors and driver input and decides how much fuel needs to be injected.
PCM's rarely go bad. I seriously and truly doubt that they have even come close to diagnosing your problem. They are more interested in making money off you than fixing your truck.
BTW, a PCM can be had off ebay for $50. That's quite a markup.
Old Apr 13, 2007 | 06:01 PM
taisa899's Avatar
taisa899
you can get a remanufatured PCM that comes wiyh a 1 year warranty here for $114.00 http://www.directauto.com/category-e...rch_year/1992/
Jim
killergsxr1
16
Dec 16, 2024 10:44 PM
87-XL-Squared
Feb 26, 2016 07:52 AM
Elisvk
Jun 17, 2014 09:19 AM
bcorg
Aug 27, 2011 07:35 AM
bennie
Apr 17, 2007 01:19 PM
