31" were an optional tire size. I would leave it alone. Try the dealer and ask but I doubt there is an adjustment. The differance is marginal and actually to your advantage. Your odometer is running just sightly slower thus accumulating less miles on the clock.
>I have a set of 31" tires on my Bronco. How do I go about
>setting my speedo so it reads right?
>Thanks
I've got 33" tires on my '84 (which is for sale BTW). I know I'm reading wrong. Here in Jax, FL, there's a shop that will measure it out and tell me what speedo gear I need in my tranny. You might wanna ask around your town/area to see if someone can do it for you. I think they put it on some sort of test rack to determine. Not sure, though.
Ron,
if you have a late model Bronco (92+), then look in the Technical section here for a neat diy:
https://www.ford-trucks.com/articles/december2001/speedorecal.php
