1978 - 1996 Big Bronco
Never done this...!!!
Old Apr 19, 2002 | 01:05 PM
emboyd's Avatar
emboyd
OK, so I'm gonna attempt to change the intake manifold gaskets on my '84 XLT, since they are suspect in a coolant leak.
I was reading the Haynes shop manual and it says to get an engine hoist (or a friend) to help lift up the manifold once I have all the bolts removed. Is it THAT heavy? I can't imagine it being that bad.
A little help please...
thanks...
Old Apr 19, 2002 | 01:34 PM
fast_eddy's Avatar
fast_eddy
It's not that heavy! It will probably be stuck down pretty well, though, and require a little prying to pop up. Once you've got the seal broken, you should be able to lift it out yourself.
Old Apr 19, 2002 | 02:32 PM
adelyser's Avatar
adelyser
Old Apr 19, 2002 | 10:12 PM
4drbrnko's Avatar
4drbrnko
It's not heavy but it is awkward. Taking it out by yourself shouldn't be a problem but setting it back in straight without a gasket slipping might be another story. It's easier with two.
1989 Centurion Classic Bronco
1979 Bronco XLT
[link:groups.yahoo.com/group/centurionconversions/|https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3476&.jpg]<-< Centurion Club
Old Apr 20, 2002 | 10:13 AM
restorit's Avatar
restorit
emboyd:
The prior posts are correct, however, you may have a factor leaning in your favor. I believe in an earlier post you mentioned that you have an Edelbrock carb (4 bbl., I'm assuming). Do you have a factory cast iron intake for the 4 bbl. (from an older engine..... the '80's truck 302's, to my knowledge, had 2 bbl.'s from the factory.)? I'd be willing to bet that you have an aftermarket aluminum intake (Edelbrock, or otherwise), which will be considerably lighter weight. You still may have a problem popping it loose, and you'll still want to consider having a friend help line it up when reinstalling, but yours will probably be easier to handle. Good luck!
Old Apr 20, 2002 | 07:04 PM
emboyd's Avatar
emboyd
>emboyd:
That's right, Mr. Restorit! I've got an Edelbrock aluminum intake. Nonetheless, I decided to just check the snugness of the bolts. So far, it all seems to be working to stop the leaking. Someone told me I should go back to this engine after a few thousand miles and check the tightness of all the bolts. I had over looked the Intake Manifold. So, all is well.
Thanks for all your help, all of you.
