Engine light, temp. gauge fluctuates wildly!
Old Mar 25, 2007 | 10:19 AM
coyote370's Avatar
coyote370
Unhappy Engine light, temp. gauge fluctuates wildly!
Wow, what a scare! The engine light came on last night after a few miles driving so I immediately stopped and checked oil (I've got an oil leak). Oil was fine. OK so I thought I would try again the light was off then the temp shot up fast and light came on again, went off temp went down, then on again & up it shoots . I sat on the roadside wondering what to do and then noticed with the trucks ignition only on, not started the guage kept doing the same thing! I just had the valve cover replaced 3 days ago but still have a bad oil leak at the oil cooler. Is this just an electrical problem? What are the signs of a bad oil pump? I am a female who needs a little good advice as it is my only transportation. BTW it sounds and runs just as good as always, no new noise, smell etc..nothing burning. Help!
Suzanne
Old Mar 26, 2007 | 09:02 AM
EPNCSU2006's Avatar
EPNCSU2006
Sounds like something might be wrong with the temperature sender for the gauge. I'm not sure what engine is in your truck, but if it is a V8, the gauge sender is located in the front driver side of the intake manifold, just behind the distributor. Maybe that wire is getting pinched or something from when the valve covers were replaced. Grounding the wire will cause the gauge to go to the full hot position.
