Lifting a 460 engine
Old Mar 25, 2007 | 05:43 AM
1979F250Ranger's Avatar
1979F250Ranger
Hey all, first post here. I have a 79 F250 supercab with a 460 out of either a 77 or 78 car. Problem is my oil pan is leaking. I have the oil pan loose but can't seem to jack the engine up high enough to get the pan to clear the crossmember. My question is, what size bolts do I need to use in the front and back of the engine to use a hoist on? I am planning to rent a hoist and get this done this week. Thanks for your help.
Old Mar 25, 2007 | 05:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
3/8" will work. Many people just use a couple bolts in the manifold.
Old Mar 25, 2007 | 05:56 AM
1979F250Ranger
Those should be grade 8 bolts, correct? Also what is the thread size or is just standard? Thanks
Old Mar 25, 2007 | 06:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Grade 5 is better, coarse thread.
Just pull a couple bolts and use slightly longer ones from the junk box or the store.
Old Mar 25, 2007 | 08:54 AM
wizzard351's Avatar
wizzard351
i have a plate i use the go's on the intake with the carb removed.the plate bolts on with the carb studs and has a peice the comes up with 3 holes for hookin a chain to.it works good and ya can keep the engine a lil more level
