1978 - 1996 Big Bronco
Rear Leafs
Old Apr 16, 2002 | 01:48 AM
Riso79's Avatar
Riso79
Rear Leafs
Does anyone know of a set of replacement leaves that ride nice. I had a set of add-a-leaves with the stocks and then had a set of leaves made from a place in Southern California and the ride is very harsh on the freeway. Going thru dips the back end just wants to buck up. I have new rancho 9000 shocks and have tried all the settings on them. Any suggestions of what is working for you would be nice. I need them 6-7 inches over stock.
Old Apr 21, 2002 | 12:32 AM
Riso79's Avatar
Riso79
Rear Leafs
I take it that there are no nice riding leaf springs.
Old Apr 21, 2002 | 10:57 AM
restorit's Avatar
restorit
Rear Leafs
I think you hit the nail on the head. You might consider installing new springs. Over time, the originals will become worn and lose their "springiness" (sounds technical, doesn't it?). While yours may not visibly sag, they still won't provide the smooth ride of new ones. Add-a-leafs will increase the load bearing capability, and provide some increase in ride height, but they'll stiffen the ride even more. I haven't done it yet, so I can't give you a first-hand report, but I'm planning to replace mine with a new set as well as installing the flexible-type shackles that I started seeing on the market a year or so ago. I just referenced this in a post in the '87 - '96 Trucks section...... I believe NAPA carries them and they're reported to make a considerable difference in ride quality. Hope this helps!
Old Apr 22, 2002 | 12:58 AM
Riso79's Avatar
Riso79
Rear Leafs
What is the site. Where can I find out more about these flexible shackles. This sounds like a great idea. I would love to here from someone who has tried that set-up.
Old Apr 22, 2002 | 06:58 PM
restorit's Avatar
restorit
Rear Leafs
Riso79:
There's a fairly fresh post over in the '87 - '96 Truck & Van section titled "Smoother Ride". Here's a shortcut : https://www.ford-trucks.com/dcforum/DCForumID39/3960.html . Do a search for Velvet Ride Shackles, and also check with your local NAPA. Good luck!
Old Apr 22, 2002 | 07:37 PM
magyar's Avatar
magyar
Rear Leafs
bigbadassfords
Oct 1, 2013 05:52 AM
fun_on_road_daily
S. California Chapter
Apr 2, 2012 11:40 AM
rpol7966
Jan 21, 2009 07:25 PM
BradyCouchman
Sep 17, 2008 06:06 PM
blksuperman
Sep 22, 2005 11:46 AM
