question for the techs
Old Mar 24, 2007 | 07:56 PM
wb6anp's Avatar
wb6anp
Wher on the engine does the computer pick up it's intake temp reading, was curious so set my edge to display intke temp, 60 deg air temp crusing at 68 mph intake temp was 120 deg. would zoodad mod ower this temp.
Old Mar 24, 2007 | 09:39 PM
ReAX's Avatar
ReAX
I don't know if the diesels have MAF's or not, but newer ford MAF's incorperate an IAT sensor. My IAT reads very high too, but I'd rather suppy cooler air than trick the computer. I am thinking about heat shielding the intake tube and heat deflector as soon as I can find some that looks good.
Old Mar 24, 2007 | 10:28 PM
Maxium4x4's Avatar
Maxium4x4
You have 2 air sensors one is in the (IAT2) intake manifold the other is IAT1/MAF sensor.
The zoodad mod allows more fresh air and a bird or 2 as a draw back......
Old Mar 25, 2007 | 10:07 AM
wb6anp's Avatar
wb6anp
ok thanks for the temperature reading I'am getting, the sensor it is reading probably in the intake manifold after the turbo.
Old Mar 25, 2007 | 11:48 AM
Maxium4x4's Avatar
Maxium4x4
Yep, once the turbo compresses the air it raises the temp, then sends it through the inter-cooler and finally into the intake. Several companies offer an after market inter-cooler. That would lower your intake air temp.
