Getting a temp. sender to seal.
Old Mar 24, 2007 | 07:42 PM
bhardy501's Avatar
bhardy501
Question Getting a temp. sender to seal.
I had to drill my new tunnel ram intake to put in a temp. sender below the water neck. I used a 37/64th drill bit, step drilled up to that size, and then tapped it with a 3/8 NPT tap. I am having trouble getting it to seal completely off. I used pipe tape and silicone gasket sealer and have gotten the best seal yet. with pipe tape only it leaked very bad. I am afraid to try to tighten it any more due to the possibility of stripping it out. It still wants to leak just a little bit. Any suggestions?
Old Mar 24, 2007 | 09:48 PM
ReAX's Avatar
ReAX
I wouldn't mix the tef-tape and sealant, tef tape works better with a mechanical seal. Try just your RTV. NPT is a tapered thread, it sound like you may have threaded it to far. When I over threaded a NPT hole, I used a copper gasket sealant that did the trick.
Old Mar 24, 2007 | 10:13 PM
bhardy501's Avatar
bhardy501
Thanks I may have to try that. When I threaded the hole a machinist freind told me to leave approx 5 threads on the tap outside the hole, not to tap it to the end of the threads. I left about 6 threads exposed, that is as far as I could get it to go. It kept turning in the holder as I tried to get that last thread down to 5 exposed.
Old Mar 24, 2007 | 10:18 PM
ReAX's Avatar
ReAX
It should have got difficult to turn about half way down the tap, depending on the thickness of the material. The taper is what should make the seal.
Old Mar 24, 2007 | 10:21 PM
429f150's Avatar
429f150
Pipe dope usually works pretty good too alot better than tape in my experiences
Old Mar 25, 2007 | 03:43 PM
bhardy501's Avatar
bhardy501
Thanks for the tips. I have several things to try, one of them should work.
