97 crewcab
Old Mar 24, 2007 | 09:46 AM
mudguy33's Avatar
mudguy33
97 crewcab
I cant get in to the back door of a crew cab any help
Old Mar 24, 2007 | 12:48 PM
Skandocious's Avatar
Skandocious
What do you mean? It won't open? Somebody else was having that problem on here, the opening mechanism was seized up. I think he had to remove the seat and then remove the door panel from the inside, if memory serves.
-Chris
Old Mar 24, 2007 | 01:31 PM
frederic's Avatar
frederic
I had one of my back doors stick after it wasn't opened for about four years, and that's how I got into it and greased the mechanism. Took out the rear seat, removed the door panel, looked inside and found that the water squeegie thing on the outside of the window (top of main door body) was actively leaking and the water was landing on the mechanism. WD40 to clean and work free, a little wire brushing, then a huge smidge of wheel bearing grease while moving the mechanism around and viola, I will not have that problem again.
I'm still waiting for the other rear door to sieze up.
Old Mar 24, 2007 | 03:23 PM
mudguy33's Avatar
mudguy33
thanks i got it 'diddnt have to take out seat ,snuck it past.
mudguy
