1978 - 1996 Big Bronco
wiring problem
Old Mar 23, 2007 | 11:10 PM
cfrives3's Avatar
cfrives3
wiring problem
Spent today trying to figure out why I had hazards and turn signals in the front, and only turn signals in the back. Chased it down to the wiring in the column and got it lined out. But before I got it completely back together I now have everything but the left turn signal. I thought that the flasher might be screwy, but the right signal works just fine and I changed out several flashers to be sure. The original problem was found to be the turn signal cam, and I replaced it. Not the whole wiring assembly, just the cam with the two little wires. Everything is showing to have power exactly where it should, so now I'm really confused. Any ideas?
Old Mar 23, 2007 | 11:55 PM
ag30265's Avatar
ag30265
Did you try replacing both flashers? Have you checked the grounds on the lights themselves, the ones in the housings?
Old Mar 24, 2007 | 12:02 AM
cfrives3's Avatar
cfrives3
Have not checked individual grounds as all lights will work, just the left side won't flash. I have changed out both flashers several times as the fuse box is hanging due to my searching for the aforementioned problem all day. Wierd. The front has a brand new bulb on the left, hazards flash all around, an brake lights are now functional too.
Old Mar 26, 2007 | 10:49 PM
cfrives3's Avatar
cfrives3
Found it-problem was in the column. Whodathunkit? Got her working with a $12 part instead of the whole turn signal switch and harness assembly.
