turbo install secret?
Old Mar 23, 2007 | 07:07 PM
hedhntr's Avatar
hedhntr
I cant get the clamp on from the back of the turbo. Theres not a stitch of room whats the secret
Old Mar 23, 2007 | 07:24 PM
indebt's Avatar
indebt
get a thick old blanket and lay it on the engine and crawl up in there....then spray the crap out of it with penetrating oil.
Old Mar 23, 2007 | 07:26 PM
Uzumati's Avatar
Uzumati
Spray her down with PB Blast or WD40 and let her soak a bit.
Old Mar 23, 2007 | 07:31 PM
hedhntr's Avatar
hedhntr
Thats how I took it off but cant seem to squeese her back on
Old Mar 23, 2007 | 07:35 PM
guzzle92's Avatar
guzzle92
If I recall correctly, the last time I had the turbo off, I had to slide the clamp up the up-pipe and position it over the flange when it was VERY loose. The up-pipe and turbo have to be in perfect alignment for it to fit over the flanges and I also positioned and started the clamp before torquing the pedistal bolts. (edit: turbo to pedistal bolts.)
Old Mar 23, 2007 | 07:52 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Exactly which clamp are you referring to? I believe there is an issue with a locating pin on the up Y-pipe. If not aligned, you will not get it on. Is that the one? I've not had mine off but seem to recall this problem from others.
Old Mar 23, 2007 | 08:00 PM
Uzumati's Avatar
Uzumati
I completely read that one wrong I thought you were still trying to get it off.
Tenn and guzzle are dead on, that pin must be in the alignment hole and the turbo being loose helps alot.
Old Mar 23, 2007 | 08:14 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Before you installed the turbo in the pedestal, did you slide the clamp back and over the up pipe collector, and hang it out of the way, not to inhibit the install of the turbo? That was easiest for me, becuase once you align the dowel pin in the hole, you can pull the clamp forward and its right where it should be.
