1978 - 1996 Big Bronco
side molding
Old Mar 3, 2002 | 05:58 PM
tothfngclw's Avatar
tothfngclw
side molding
Old May 1, 2002 | 08:38 AM
tapenick's Avatar
tapenick
Post side molding
I recently removed the chrome from around the wheel wells and was thinking of removing the rubber side molding and the brushed panel on the tailgate.
I'm pretty sure the molding is just glued on the fender and quarter, but is it bolted on the door?
And what about that tailgate panel? Would removing that leave holes?
Tom
90 XLT
Old May 1, 2002 | 02:40 PM
93bigbronco's Avatar
93bigbronco
side molding
molding is just glued to the door. not sure about the tailgate. Dave
Old May 1, 2002 | 07:32 PM
restorit's Avatar
restorit
side molding
Removing the tailgate panel would leave holes..... it's held on by little studs (attached to the panel) that pass through the outer gate shell, which are backed by small well nuts from the inside of the gate. If you open the gate and look along the inside edge, you should see a couple on either side. There are more located inside the shell, behind the window assembly.
