Sponsored by: Auxito
control arm adjuster's
Old Mar 23, 2007 | 03:59 PM
rouschfan's Avatar
rouschfan
Question for you guy's,, I have a 2000 F150 2 w.d. 4.2, manual transmission I am replacing the upper and lower control arm's, don't want to sound like an idiot, but,,,,,,,, where in the world does the cam adjuster's go ?? I have read that you should install them if you replace those part's, but my old one's don't have them an i can't see where they would go, also, should i install them in both the upper an lower ? can some one please help me out, or point me to a link that will ? Thank you
Billy
Old Mar 23, 2007 | 04:35 PM
ubereal2's Avatar
ubereal2
The adjustments for camber and caster are on the upper control arm's only.
If you are replaceing the factory parts. They're just a mostly square/flat metal plate. If they are adjustable aftermarket, they are round with a offset hole that the bolt runs through.
Bob
Old Mar 23, 2007 | 09:19 PM
rouschfan's Avatar
rouschfan
Thank you Bob, I am replacing them with factory, the ones that i took off does not have the adjusting bolt in them, from what I read on here, and other site's, they recommend putting in an adjusting bolt, well i purchased that, but i can't tell where it is supposed to go, because the old one did not have it. Were should it go ? It look's like from the holes, it goes in the rear, is that all there is to them is a bolt, with an oblong washer attached, any help would be appreciated.
Thank's
Billy
Old Mar 24, 2007 | 01:53 PM
rouschfan's Avatar
rouschfan
Can anyone help me out ???? Please
Old Jul 7, 2007 | 07:13 AM
focuszx3lover's Avatar
focuszx3lover
there should be 2 per side they go where the old bolts were they hold in the upper control arm ?? is that more clear for you
Old Jul 9, 2007 | 10:41 PM
rouschfan's Avatar
rouschfan
yes, thank's for your reply.... i figured it out after purchasing the kit, i installed the kit and about have my truck on the road, just need a few body part's. Thank's FocusX3lover
