speaker choices
Old Mar 23, 2007 | 01:49 PM
schneidz's Avatar
schneidz
speaker choices
does anyone have an opinion on which i would be happier in an 04 scab
polk db570's
or
infinity kappa 682.7cf
i listen to mostly classsic rock, thanks in advance
Old Mar 23, 2007 | 02:19 PM
bridge's Avatar
bridge
Sick 'n Tired
They're both good choices, however, the polks are a better choice if only replacing the factory speakers. Go with the Kappas if you will be wiring in an amp as well.
Old Mar 23, 2007 | 10:24 PM
deisele75's Avatar
deisele75
I like the infinity....
You may also want to consider something like this....
http://cgi.ebay.com/04-07-Ford-F150-...QQcmdZViewItem
Old Mar 23, 2007 | 10:53 PM
jvoigt's Avatar
jvoigt
I have had Polk db570's and they were great speakers...They were in my '99 F150. They have a High sensitivity that makes them work well with the under powered factory head units. Polks are very nice and the build quality is the best I have seen in speakers in that price range.....Next in line to the polks I would have to say the Infinity's but they will not sound as good as the polks will sound with your stock stereo. Good luck!
polk db570's
or
Old Mar 26, 2007 | 08:57 AM
KevinM's Avatar
KevinM
I have the Kappa's in the front doors and the Polks in the rear door. Sounds 200% better. I suggest you use dynamat with the new speakers. They will have a lower end and cause the doors to vibrate. The dynamat will kill the panel resonances.
The Kappas are a little brighter then the polks. The two together keep the highs under control.
