no power
Old Mar 23, 2007 | 08:04 AM
Jasonf's Avatar
Jasonf
Cool no power
First off I would like to say hellow to all you guys. I purchased a 1999 F250 with the 7.3 turbo with 75000 miles when I get to about 2500 RPM it falls on its face there is no check engine lite nothing if I take off easy it does fine. Any help would be greatly appriciated.
Old Mar 23, 2007 | 09:47 AM
CobraXP's Avatar
CobraXP
Welcome to FTE Jason!
I'm going to move your thread the the Super Duty Forum. This is the Announcement and Introduction Forum. Since we don't allow technical Q&A in this forum, I doubt you will get a good answer, but I'm sure the guys in the Super Duty Forum will have more than enough ideas to help you get that 7.3 up and running like a champ!
Good luck and again - Welcome to FTE!
(Don't forget to check out the Indiana State Chapter also! )
Old Mar 23, 2007 | 10:52 AM
Beerstalker's Avatar
Beerstalker
I would probably guess that it is a turbo issue, but there are many people that know more about the 7.3L than I do.
You might also consider asking this question in the 7.3L diesel forum.
Old Mar 23, 2007 | 12:00 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
And now, this thread is in the 7.3 forum Good luck!
Old Mar 23, 2007 | 01:17 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Bad fuel filter?
Old Mar 23, 2007 | 01:37 PM
Uzumati's Avatar
Uzumati
Lets join these two threads https://www.ford-trucks.com/forums/594308-no-power.html
Old Mar 23, 2007 | 09:19 PM
superduty0373's Avatar
superduty0373
check fuel pressure,oil level,oil quality you might have a oil aretion problem this is caused from old/bad oil quality.
Old Mar 23, 2007 | 09:25 PM
kennedyford's Avatar
kennedyford
How do you mean it falls on its face. Does it wind up and not go anywhere. Does it feel as if the brakes were applied? How about as if the tranny went into neutral or loses a gear? Smoke, guages anything can help us troublshoot this for you.
Old Mar 23, 2007 | 09:34 PM
hucka1a's Avatar
hucka1a
Check the tube on the waste gate, make sure its connected. Also welcome to the FTE 99+ 7.3 forum. These guys really know their stuff! (I'm still learning)LOL
Old Mar 24, 2007 | 07:51 AM
Sabre2th's Avatar
Sabre2th
Ran into this on a bud's truck a couple years back, had a real 'flat' spot from around 2200rpm and up. Was clogged pickup in the fuel tank. Figured it out by blowing low-pressure compressed air back thru fuel line behind the fuel pump. Problem went away for a while so he ended up pulling the tank and modifying the pickup. I did mine at the same time so I wouldn't have the same problem, no regrets!
Tom
