flywheel to converter problem
Old Mar 23, 2007 | 07:11 AM
goofy_don's Avatar
goofy_don
how do you get the tc to slide up to flywheel. Tc bolts thru holes in flwheel but cannt pull converter closer to get bolt on them. 1994 4x4 ranger
Old Mar 23, 2007 | 08:08 AM
Rags's Avatar
Rags
If your starter is still out, reach through there and pull it in. Itshould slide right in as long as it is lined up correctly. The center hub of the converter may be bound alittle.
