Gear ratio questions
i was curious if you can put 3.50 gears in the rear diff and 3.55's in the front without causing too much stress on the drivetrain. i use 4wheel drive in my truck when i go four wheelin as well as going over the pass in the snow etc. so it will be used on the highway some.
thanks
86 f150 , 9 inch rear, dana 44 front
thanks
